Clears one or more ELSM-enabled ports that are in the Down-Stuck state.
| port_list | Specifies the ELSM-enabled ports that are permanently in the Down-Stuck state. |
N/A.
If you do not have automatic restart enabled, use this command to transition ELSM-enabled ports that are permanently in the Down-Stuck state to the Down state. You can also use the enable elsm ports port_list auto-restart command to transition a port from the Down-Stuck state to the Down state.
For information about the ELSM-enabled ports states, see the command show elsm ports.
If automatic restart is enabled (this is the default behavior), automatic restart automatically transitions the ports from the Down-Stuck state to the Down state. For more information, see the command enable elsm ports auto-restart.
clear elsm ports 2:1-2:2 auto-restart
This command was first available in ExtremeXOS 11.4.
